yea but a manual rack has a larger lock to lock ratio than a power steering rack. I dont think ive ever seen a pump delete kit, do you have a link? I just hit up home depot and target, built a catch can.
Removed the 2 hardlines going into the rack, installed 2 correct sized fittings. Ran 2 3/8ths hoses up to a catch can with a breather on the top. Have the fittings on teh can as low as possible to allow fluid to cycle. The can I constructed from target, which was an aluminum soap dispenser. Looked just like a profesional catch can.
Add just enough fluid to stay just about the level of the fittings, because hard cornering will spray fluid everywhere esp at high speeds. The system is under pressure so make sure its leak free.
Thats the easy part, there is something about a seal in the rack that seperates and prevents the fluid from fully cycling like a manual rack, I cant find any info tho.
