I need help with my clutch...
xsubxwooferx
Well since yesterday, everytime I change gears I got to push clutch to the floor and barely let off to feel it catch. Well today when I went to try and drive around, when I put clutch to the floor it didnt pop back up. I keep pumping on it and it finally starting pumping back up but still wouldnt let me change gears. Is it my master cylinder?
lotz6996
check the oil, it uses dot 3 oil just like your brakes, also check the lines to make sure none of them are broken or leaking.
xsubxwooferx
I will say my resovoir or however u spell it for clutch is below the tube sticking up...Theirs also no leaks as of under the car so far. Ill check lines now.
lotz6996
you also might need to bleed the clutch line.
first_build
It could be a blown clutch master or slave cylinder. Check to see if they leak and replace then bleed the lines.
xsubxwooferx
My master cylinder was leaking so bought another one of those and ending up getting a new slave cylinder to.80bucks Bled it to..Fixed. Thanks.
