lca's
bizoneoeh
Ex-Gang Member
stock LCA's
Esotericimage
Taking an H-T break
^^ true.. LCAs are just for bling. Check your rear trailing arm bushing if things feel loose back there. if its old and cracked, time for a replacement.
Szady
D-Series Master
If you dont want stockers, then look at Blox. Theyre only $120/set shipped or so off eBay....
HatchmanEJ6
Mmmonocle smile!
so i dont mean to thread jack, sorry!!! :oops:
so from what you guys are saying i wouldnt have to replace my stock lca's even if I get new suspension? e.g f&f type 1's?
EK|B
No you don't. Unless your bolts are seized onto the bushing.
ekblack97
all cool man im also replacing my suspension on summer w/ f&f type 1's.
got traction
i rock the sohc
Don't the rear LCA's help with camber on lowered cars?
negative cheif, the camber is adjusted by either purchasing a camber kit, or by adding washers. Here it is circled in red for your viewing pleasure ;)
oc_civic
i replaced mine because when i did my suspension the bolts were seized and rather than deal with the bullshit of trying to get them out.. i just cut out everything and put omni LCAs in.. they look better but thats about it IMO..
Sammo115
It be me, Sammo
blox LCA's are good, bushings are much better
Blox LCA bushings good? I think not. Read up about what people been saying about their bushings ;) I even had a bad experience with their bushings.
HatchmanEJ6
Mmmonocle smile!
so... is it the same story in the front? meaning is there a possiblilty the bushings in the front will be f$%ed up and you may have to get a front camber kit as well?:???:
