Leaking ABS pump
ryn004
I constantly have to top up my brake fluid on a weekly basis. You can find it leaking from underneath the abs pump.
My car is a 94 Civic (EG9). Do you recommend I change the pump? If so do I go for a used one or a new one?
nyjprice
Lol I have the same problem with my LX I would like to kw too
You need to more precisely pinpoint the source of the brake fluid leak. My guess is that the leak is from one of the many brake line connections to the modulator pump unit. In this case, the fix may be as simple as tightening the brake line nut with a flare wrench.
ryn004
Just checked it out, and it seems as the resovoir tank is over flowing. That is the cap of the resevoir tank is soaked in hydraulic.
has this ever happened to anyone?
RonJ - where can I download the pdf with the compelte ABS removal instructions?
There is a link to the 92-95 service manual in the 6th Gen sticky.
Why do you believe that the ABS system is at fault? Any ABS codes?
