ive dropped my car about 2 inches maybe less i got it toe aligned and i have about 1.5 neg front and 2 or more on the rear camber. im still getting inside tire wear why?
Get a front camber kit and get your car realigned.ive dropped my car about 2 inches maybe less i got it toe aligned and i have about 1.5 neg front and 2 or more on the rear camber. im still getting inside tire wear why?
everything is new shocks, top mounts, springs. upper control arm, lcas, and rear and front camber.How long has it been? Do you have anything damaged in your suspension?
you should use the correct psi for whatever tired you have. having over or underflated tires can cause many problems.i got 1.5 in front 1.25 in rear I noticed my rear dont wear but my front do, I lowered the psi down to 30 and since then they wear evenly luckily, no camber kits.
excatly right i took it back to the place nd it was both off in the same direction they set back for free i also raised to to align camber, it was all corrected for free because of their error.sounds like the shop didnt align it correctly.
huh?skunk2 camber kit. its that easy bro. the are so much easier and faster to align then stock, give better clearance, the ball joints on the front are godly, and all togother some camber kits are some cheep do compaired to replacen tires all the time.
x 2huh?
