You can go the cheap route and use your stock shocks with a low spring rate lowering spring. The only one i'd suggest is the OE H&R's or Tein S-techs. The springs and alignment should run u at least $200-$300.I wanna lower my civic lx 2000 'bout an inch, but will the new lowering springs (watever brand they are) fit the stock pieces on the car? or would I also have to replace all that stuff?
A 0.75" drop is not good for anybody.H&R OE Sports will be good for you. You will notice a difference since the spring rates are higher than stock regardless, BUT it might not be a HUGE difference.
