JDMcivic77 New Member 5+ Year Member May 17, 2010 #1 just swapped an ls Vtec motor into my eg coupe runs and starts great. buttt its slow as balls it takes 20 sec to hit 30mph i was thinkin my timing is way off? does anybody haved any ideas on whats wrong??????
stickeyrice84 New Member 5+ Year Member May 17, 2010 #2 you need to recheck your timeing sounds like a tooth or two off
JDMcivic77 New Member 5+ Year Member May 18, 2010 #3 its off by a hair could that cause it to do that ?
Del sol-R New Member 5+ Year Member May 18, 2010 #4 Check your timing,valve lash, and make sure you have the proper ecu for your swap or chip.
purpej1 honda fiend Registered VIP May 18, 2010 #6 yea ecu,get it tuned and also what tranny you running
stickeyrice84 New Member 5+ Year Member May 19, 2010 #8 is the hair like a tooth, and u might need to have that ecu rechiped to run the best that it can with the set up u got going on
