Malfunctioning breaks Honda 98?
#1
I have a 98 Honda civic.
I have new front breaks.
While I was driving my handbreak light kept turning on and off. I parked and when I went to use my car again, my foot break had no more pressure and went straight to the floor and very slowly started to slow down and I had to use my hand break to stop.
Any idea's of what happened?
how much will it cost to repair?
chromal
#2
The brake light can turn on if the hand brake is pulled. It can also turn on if the brake fluid reservoir is low. It sounds like you may have a brake slave cylinder leaking, or possibly a leaking brake line. Look for brake fluid on your wheels or inside the wheel wells. Caliper rebuild kits cost about US$5, removable brake lines are pretty cheap, too. If it's a hard line or the master cylinder that's leaking, you're looking at something more expensive. If you pay a mechanic, you're probably talking about at least US$100 or up.
JohnS.
BANGARANG
#3
Agreed. Low brake fluid seems to be the most likely cause for brake lights that come on. I would start at your MC/firewall and check for leaks.
VigLink badge
