An update:
cleaned, honda bond applied, and qsd plate installed
the KStuned tensioner came in time while installing the plate.
Some polish treatment
The timing belt is rubbing against the pulley bracket causing the belt fibers to flake. I believe its a bit tight so im going to play around with the manual tensioner.
I lined the cam gears up and engine cylinder 1 is at TDC. I also marked the gears and belt to make sure they're lined up but when I installed my KStuned manual tensioner and rotated the engine a few times it doesn't line back up with the marks I made on the gears and belt. But the horizontal lines on the gears always line up when at TDC. Now heres my question, as long as my cam gears line up after each rotation and cylinders are at TDC, everything should be good right?
