my car is shaking like crazy
rayej8
So I got this new tire on my car I got. Mounted and balanced I thot from the balancing the car wouldn't shake at all anyone know wat it could be do I need an alignment again???
JustJustin
I bet you the rim isn't fully on. jack it up and take off the wheel and see.
00siboy
lurkin...
So to clarify, you got just one tire, not all four? Which one was it and does the steering wheel shake?
JustJustin
if your wheel is shaking they probably didnt balance it
DeathLens
EM1 Crew
did it start happening after you got the tire changed? could be loose lugs or they didn't balance it or wasn't balanced properly. if it was doing it before, check and see if you have any damaged components. a bad alignment will not cause shaking or vibration
rayej8
ok so thanks for all the replies i didnt drive my car yesterday and i decided to jack up the car now most of you guys willb lik wat an idiot but my cousin put in my camber kit but i guess forgot to tighten the screws i was driving off of only 1 screw really scary to know that but i bought new ones and i soaked dem in thread lock before tightening them lol
Avant Uprising
GONE FISHIN
Better check any other part he worked on lmao. If there was beer involved that would explain it. Jk
Sent from my LS670 using Tapatalk
JohnS.
BANGARANG
Why you would use lock-tite....? You just dug yourself a very deep hole. because in the event you need to remove them (replace ball joint / camber arm, something breaks), you're going to have LOADS of fun.
obracer12
blue will break loose with a sharp shock... red on the other hand... you may end up heating it.
rayej8
i used the blue one fellas i aint dat stupid come one guys its common sense
gugiey
that's what a breaker bar is for .
