After installing the type-r intake mani and throttle body on my b16a2 (99 si) the motor will rev to redline when cranked. the throttle is closed and the pedal is not to the floor. what would cause this?I switched the throttle bodies so all the sensors would be the originals but that still didn't work. the tps and iacv should be fine( i've read that the tps might need to be adjusted but I don't see how it got out of adjustment in the first place) all the hoses seem to be fine. Nothing is leaking either. all bolts and nuts connecting the manifold are tight( and new gasket). there's some kind of electrical plug that is hanging under the manifold that is coming from a wiring harness but I cannot figure out what it goes to. I'm pretty sure it plugs into the block or head right under the manifold. but I'm not sure. it's weird as soon as the motor turns over it just revs right up until I shut it back off
any help would be appreciated!!!
**cliffs**
put type-r intake mani and throttle body on my b16. everything is hooked back up fine, no leaks, but the motor will rev up like its WOT when I crank it up. i'm thinking either vaccum leak or electrical problem. there is a plug underneath manifold that i cannot figure out where it goes.
**cliffs**
