Need help for my starter
4D2Envy
ok so im about to change out the starter in my car anyone have any tips on how to change it and what size wrenchs and or sockets will be needed any tips would be most helpful thanks!
B18cbubble
just unplug the battery first, i think the bolts are 14mm, undo the wire harnesses for the starter, and take it out. then just put the new one in. there is nothing special that you need to do. its pretty easy. good luck!!
4D2Envy
i ment is there a easy way to get to it or should i just go with pulling off the ram air intake and thats enough room?....ive changed starters before just not on a FWD
NFR_AP2
taking the intake off will help...your gonna need a 10mm wrench to take the battery terminal off, then a 12mm to take off the cable that bolts onto the starter, then a 14mm to unbolt the starter from the tranny, should take you more than 10 mins...
