bigskyeric
Ripped off the exhaust last night and figured out why it was rattling and leaking so bad. The metal sleeve inside of the Resonator was loose and rattling around inside, so I took a metal bar and bent it so it stays in place. (No more annoying rattling, wooohooo) the big pipe,that I have pics of on here, was loose and had a big hole in it from bottoming out.(probably on a speed bump) When I put everything back together I used exhaust cement. And I took the hole in the pipe (about the size of a penny) and covered it with a piece of tin foil and exhaust cement. I folded the tin foil up into a 2 inch square then used metal wire to hold it in place. Pretty ghetto, but this is a budget ride for now, and it is hidden and did the trick. Total cost of repair about $4 in tin foil, wire, and exhaust cement. Better then the $100 the shop quoted me. Total time, about 1 hour.
