More info please what kind of noise, is your car lowered, do you feel any sort of clanking or instability when turning so on. The more in depth info you can give the better we can help
This is clearly not a DIY post so it has been moved into the correct section. Please read the section descriptions before posting. Using the correct section improves your chances at receiving helpful answers.
I also changed your title and moved yours into your post as its more of a sentence. Making titles short & to the point keeps it visible in all views.
If by snapping you mean a clicking sound then thats most likely a worn axle & cv joint. Search for that and you'll learn what that means. They're relatively inexpensive to replace. You dont seem knowledgeable with cars so its best to get it done at a mechanic. Your research will show you how the job is done.
