i can get a gsr head for cheap but its obd2 and i need a obd1 whats the difference between obd1 and obd2? i know injectors, distributor? what else? is the harness different to the obd1 because it comes with a full harness also. thanks! for any help
what he said it will be alot easier for youI recommend looking up obd1 conversion.
Yes, as long as you are using all obd1 parts. b/c I just did.so my obd1 harness will be able to plug and play with the obd2 with all that modifications done to it?
Nope, but the obd2 motor has the iat sensor in the intake tube instead of the intake manifold I believe like the older obd1 one has.so does the itanke manifold make a difference?
