When connecting your oil line to the concave plug on the turbo(function7 adapter) do you use Teflon tape or not? I was driving my Civic and boosted my turbo up to around 10psi, before it was around 3 max...when I did that the oil line (braided steel cable) basically semi stripped and oil started leaking on the turbo and on the right side of the engine bay. Not sure if I maybe did not have it tight enough, but Im sure I did, but looks like some oil must have got in between the two pieces, is really the only thing I can think of that caused this??? we changed the oil line to another braided line and it alteast will tighten down on it but still leaks a lil oil.....What do you all use for that piece and have any of you had this issue and the solution you came up so it did not do it again, as if you did not check it, you could lose quite a bit of oil and really ruin the engine, fast...luckily I think caught it time and everything is OK.....
