just replaced mine. pretty easy to do. take intake and exaust manafold off, take off distributer, take off valve cover, "COOL LITTLE TRICK..... mark timing belt and cam gear, loosen timing belt, slide it off the cam gear KEEP TENTION ON IT SO IT DOSENT SLIP ORFFOTHE COMPONETS!! USE BUNGE CORD TO HOLD TENTION UN TILL YOU PUT IT BACK ON. THIS WAY YOU WONT HAVE TO RESET THE TIMING" Tanke the stud bolts off. pull head! send it to a machine shop to have it resurfaced. clean any old gasket off. put on new head gasket. place head back on. now on re torqing the studs, i dont remember the spects right off (I BET RONJ DOES) you will do 3 seperate torqse on them. oile everything back up, keeping tention on the timing belt slip it back on tcam gear lining up ypur marks. replace distributer, replace valve cover, intake, and exaust. fire it up and haul ass!!
