Oil Pan Tread possibly stripped
legion
digital agent
Last time I got an oil change, the shop said that I need to get a new oil pan because the tread on my current one was stripped. Been calling around and those oil pans are pretty pricey! Supposedly you can only get them from Honda ~$250, then labor, etc...
Some places I've called said that I could get it re-treaded (re-tapped, another guy called it) and just use a bigger drain plug. Others have said that that's not a good idea and I should just replace the oil pan.
Anyone ever have this problem? Thoughts? Suggestions? They would be much appreciated.
scottyfordy
Mopar Muscle
Patch the hole and make a new one.
gabebauman
Sk8aholic
Mine stripped out a couple years ago, I actually went to the autoparts store and bought a longer plug bolt and it's worked fine ever since...it's even one of those magnetic tipped ones.
mugen_tuned
4G63-T
you have two economical choices, one would be take it to a machine shop and have em weld the tread and then tap in the new tread to oem spec, two would be tap in a different tread over the oem tread and use a different bolt in matching diameter and tread pattern. or you can go with gabebauman's suggestion, i dont think anything would go wrong with that but im always one to fix something to original specs, its my curse and i cant help it, lol.
Tom
honda.co.jp
another option may be just to buy a new oil pan, i just did that recently.
Tom
honda.co.jp
moroso would be a great upgrade if you need to replace the pan, i think that may be the best option.
