Power window does not work
lumpkcha
Good Morning, I own a 1999 Honda Civic. The power window on the passenger side stopped working. It worked fine 2 days ago. I cannot open it using the controls on either the driver side or passenger side. I'm stumped. Does anyone have any suggestions? Please and thank you.
does the power window motor still work? can you hear it when you press the button? if yes then im guessing its your window regulator is worn out not the electric window motor. its not too hard to replace you have to pop open the door panel with a flat head screw driver i bet the regulator and motor are pretty cheap. my window and sunroof do some funky stuff also check out my utube channel for how to videos. good luck
