ok i've got a 95 civic ex with a d16z6 with a s20 trans. my trans went out so i'm replacing it with a 99 s40 ex trans. i figured since the trans is out i might as well replace the throw-out and pilot bearings just to be safe. the question is, do i need the bearings for the 95 ex or the 99 ex? also i know it will bolt right up but is there anything else i will need or do i just need to swap my mounts over to the new trans and bolt it in?
EDIT: ignore the bearing question. apparently they use the same ones.
