reichbc
"Brandon"
Cutting right to the chase. I'm asking for serious technicals, as much detail as possible, full signal path, etc.
99 Si.
How does the temperature gauge in the cluster receive it's signal (from the ECU / direct from sensor)?
If it's directly from a sensor, which one and where is it?
Would a short in the wiring cause it to jump up high?
What if I said that the temp gauge moves up and down in conjunction with the bouncing idle caused by my IACV issue?
Videos to follow later.
I also have a high idle problem (IACV circuit failure code), but i think that's cause my TB gasket is loose from taking out a throttle body spacer. I'm getting the new bolts from Honda today. Just replaced the IACV yesterday and it still idles high and pops the code so I'm thinking that the new bolts and a nice snugging should clear that up.
Thanks in advance.
99 Si.
Thanks in advance.
