Alright fellas. I got a question for you. I just recently had my head gasket, water pump, thermostat, timing belt, spark plug gaskets, valve cover gasket all replaced. Also, while re-installing I had a Megan header installed. Tonight was the first night I actually took it out on the road. When I was backing in to the garage, I noticed it was steaming from the underside of the hood. right near where the radiator cap was. i felt both the upper and lower radiator hose, and they were both hot to the touch. should they both be hot to the touch?? or should only 1 be hot? i didn't notice any leaking radiator fluid like before, but it smelled like something was burning.
any clue what it might be? maybe the header until it gets driven on a bit? maybe a new radiator cap is in the future? any help is appreciated!
thanks.
thanks.
