Does anyone know how to disable the rev limiter on a 98 civic ex without using any big mods
Get your ECU reflashed. Or a APEXi V-AFC.webcamcivic said:Does anyone know how to disable the rev limiter on a 98 civic ex without using any big mods
not to mention his sissy OEM cam wouldn't make power there so reving that high is utterly worthlessnd4sped said:Get your ECU reflashed. Or a APEXi V-AFC.
Your Redline is there to prevent you froom going any higher. Going higher can cause you to float valves. Cuasing overlap and losing large amounts of power.
unless you want to waste gas...Ace$nyper said:not to mention his sissy OEM cam wouldn't make power there so reving that high is utterly worthless
soooo do you have the cam to make it worth it?webcamcivic said:I want to do this because i have a fully buit head that can rev up to 8500 rpm but i dont have the money to buy any electronics to adjust it
ok so thats safe to assume it'll work in that head wellwebcamcivic said:i work at web camshafts and my boss made me a custom cam.
