I shall ask tomorrowWell u got my number sexy
guess I should start a little thread for the integra...might be some stuff going down on it soon. already started some
This is good news!I shall ask tomorrow
it will only be basic maintenance and little stuff, I hope. I'm trying to hold off on buying a new car for a little while and in the mean time ill fix this one up someThis is good news!
I mark distributor to the head with a line and just pop it out, change, put it back in. nothing should be changing at all. ignition timing is ran off of the intake cam and its slotted and only goes on one way. as long as you keep your marks aligned your goldenWhen it comes to changing the distributor o-ring, do you just simply put the distributor back where you had it or do you use a timing light to put it back in time?
Good to know! Thanks man, I've been putting it off for a while now. Well, that and the oil pan gasket.. But that's for another day.I mark distributor to the head with a line and just pop it out, change, put it back in. nothing should be changing at all. ignition timing is ran off of the intake cam and its slotted and only goes on one way. as long as you keep your marks aligned your golden
you could do a distributor o ring in under 10 minutes if you d**k around a lot. take the cap off so you can rotate it to go on correctly, then three more bolts and your doneGood to know! Thanks man, I've been putting it off for a while now. Well, that and the oil pan gasket.. But that's for another day.
dont hate, you know damn well that ive thought out this decision for a long long timeEye hate you
