I've got a race cat on my car which of course lit the CEL for the O2 sensor. My solution for the past year was simply to take out the bulb in the console, problem is that if anything serious was wrong, I probably won't find out till it was too late. So I went on a quest to find a MIL eliminator/simulator that would work. There is crap out there that range anywhere from $7.95-$60 that make claims that will fix this. They come in 2 flavors, one is called a mechanical eliminator, and an electrical eliminator.
Mechanical:
The basic concept here is that you plug your O2 sensor into this metal bolt looking thing, and then plug it into your test pipe or cat. It restricts the amount of gas reaching the sensor so it doesn't flag the ECU for the extra hydrocarbons that it doesn't see anymore.
Electrical
Which seems to be the more abundant of the 2, simple uses a resister(among other things) that you splice into the OE sensor wire on the O2 sensor and the ground wire, making sure to leave the heater wires alone. If you go this route, I found that on my civic, these are the green and white wires out of the 4 wires connected to the sensor. LEAVE THE BLACK ONES ALONE!
There is another electrical solution that uses a micro computer to simulate the signal, but also costs the most at around $60.
First attempt:
My first attempt was using one of the ebay MIL simulators, which was electrical in flavor and cost me about $13. After wireing it, and re-wireing it several times, my CEL would still come on after about 15 miles. Couldn't get it to work.
Solution
Next I tried a DIY I found that uses a mechanical eliminator from clubrsx.com. It cost me less then $7 and only had to do some carefull drilling.
http://forums.clubrsx.com/showthread.php?t=296791&highlight=simulator
I've got about 30 miles on my car after the install and so far so good. Just thought I would share.
Mechanical:
Electrical
First attempt:
Solution
