i swear my code blinks 12 times. stops then 12 stop then 12. so that means 12 right? but that chart doesn't hav a 12
you are counting it correctly - code 12 is for EGR valve - the problem here is that the chart that was originally posted is from the UK CRX manual and it and the method of counting the flashes outlined doesn't apply to the USDM 88-91 CRX/Civic - all USDM OBD0 D-series ECUs
do not have long and short flashes,
only short flashes - if you don't believe this and you have OBD0 D-series ECU, just unplug the EACV and count the flashes on the ECU - you will find it flashes 14 times or disconnect the VSS and it will flash 17 times or put an automatic ECU in it and it will flash 19 times - OBD0 B-series ECUs and all OBD1 ECUs use long and short flashes - here is the ECU code chart for the 88-91 USDM CRX/Civic
