what do i need for swap
hondacivicEJ1
ok so i was wondering what i need for a swap i seen i never touched 97 teggi.was wondering what should i grab from the car to do i complete swap i have a 94 civic with 1.5 so any help would be much good.
AlaskaB16
DOING WORK!
Grab the entire car... Then leave your civic behind. /
LOL.. I keed I keed! Seriously though, you'll need to provide way more info than that. Auto or manual for both cars? What motor is in the Teg now? Check on the price for the motor, trans, ECU, throttle cable, motor mounts, engine harness, shifter, pedals, all clutch parts, rear brake assembly, the list goes on and on.. Some you won't need or can't use but can resell later if the price you buy them for is right and then get the correct stuff. And you'll still need to buy aftermarket swap parts to make it work correctly in your car. This is assuming the car is stock too. It could have been swapped at one point which would make things hard to figure out for someone with out knowledge.
