I typically run 2 or 3 psi higher than the recommended factory pressure for oem setup (on your doorjam). This has worked well for me in the handling and wear department. If you underinflate, your tires will wear on the outside edges faster. If you overinflate, the center of the tread will wear faster. Find a good balance for handling and wear.
