yes, the poster is definetly correct. the vtec acctuator solenoid is dual on the 3-stage d15b, and the wires are cut when removal of the engine occurs in japan, pre-shipment.
it was then installed without being properly wired, so the CEL code for a vtec problem makes total sense.
i'll get those cam pics and crank pics around 3. and then post them up asap.
Code 14 was address earlier before i videoed the engine, etc. I took off the IAVC and cleaned it with throttle body cleaner as you directed in your sig's thread. after i let it air dry for almost 2 hours while i took some family pictures.
then i reinstalled it and wam, bam, boom.....all done.
now when i removed the IAVC, no coolant leaked. also one of the lines is blocked, since i'm using a FITV tb, but with a block-off plate over the FITV port.
a summary of problems:
car attempts to turn over when initially attempted, after around 3 tries, while "giving it gas", the engine sputters to life with a rough idle. the idle is at the normal levels...
the car has no other issues other than the possible untiming, as well as the coolant leak from the inner side of the thermostat housing....
^^about that, how should i address it? remove the IM and all other vacuum lines and then check to see where the leak is coming from?
(also that article is amazing! A21 is the glory number, thats the slot on my ecu where i need to run the second stage wire to clear the CEL.
