Correct Chris. You were previously incorrectly assigning the crucial function of the crank sensor to the coil and ICM.a bad crank position sensor could perhaps tell the ECU its not cranking.. so therefor not produce a spark or let fuel by... its basically like the car is in standby mode... even though its cranking over.
Yup. Though he didn't specify the year because it's been the same on any Civic for quire a while, I'm assuming.his profile says 97 EX
yea every single cam civic from 88-2000 had the same parts in the distributor. although not always the same part numbers... but they had the same function... the CPS sensor has always been in the distributor on a single cam...Yup. Though he didn't specify the year because it's been the same on any Civic for quire a while, I'm assuming.
Congrats
Now we need another question.
yea distributor located CPS units involve changing the whole thing... they are not servicableso.... RONJ it says you have to replace the distributor unit as a whole so he has to buy a new distributor Assembly...
If you know what you are doing and have access to the parts, one can replace distributor sensors. They are simple resistors.so.... RONJ it says you have to replace the distributor unit as a whole so he has to buy a new distributor Assembly...
its cheaper to fix it yourself yes... but... its hit or miss... if you dont have the right parts... which i dont think the CPS can be ordered... but you also need the proper tools to get it apart that far...If you know what you are doing and have access to the parts, one can replace distributor sensors. They are simple resistors.
dude this is just hondas.... lol .... i can get into some harder questions not involving hondas if youd like... loloh.....damn you guys are teaching me mechanics way better than UTI....lol keep the ? coming till then i'm out.....
Never underestimate the power of testing. I think more problems are missed because the testing is not done correctly.but sometimes it sucks that you know there is a problem... and you know what the problem is... but you are hesitant to replace it till you do your tests... then your tests lead you nowhere... so your stuck...
then you decide you just change the part you suspected.. and it works like a charm. 2 days of testing that didnt need to be done if you just followed your gut from the beggining... thats what gets me
