LoveMy05Civic
Im about to purchase some lowering springs for my 05 sedan, and I can't decide between a 2 inch drop or a 1.5, im currently running 15 inch konig feathers, but will be upgrading to 17s soon.
That's true, the 17s im getting are the konig zero-ins, ill look around and see what other 7th gens look like with a 2 inch and 17s.2 inch for the win, well I guess it also depends on the 17's. You should get the rims first then see if maybe a 1.5 would look better
Yeah I prefer them to be tucked in, and as for my tire size when I get my 17s it will be a 205/50, right now its 195/60 with my 15s.depends on the rim size/ and tires and then what is your preference. do you like your trires tucked in????
my tires are 17 with low profile tires, the rear is tucked in, but not the front. reason is, the front scrapes on the inside everytime there is a steep hilll. i have a 97 civic.
Yeah id be using my OEMs.the drop would depend on what your using for shocks are you using your oem ones ???
Ok that's what ill go with cause I definitely want them tucked.If ur going with a 2 inch you may want a 205/45 if ur trying to tuck or your going to rub my man
I also found the tanabe Df210 which would give me a 1.8 drop, i think that would be good drop??? and as for my oems it probably about time i got new ones anyway so when they blow ill get ones.get 1.5. your oem shocks will blow with 2" much faster
