Adjusting valves
dryeager
#1
Does anyone have a general or specific write up on how to do this on the D16y7? I know the clearences but am not 100% sure about how to adjust them.
nightryder99
#2
i would suggest you let that to a mecanic...atleast thats what I did on my Y8 ...and if you know him he'll hook u up with a cheap price
I got mine adjusted for like 30 bucks
highcompracing
#3
Its pretty easy, put the engine in timing start with 1-3-4-2. When the engine in timing start with number 1 first then turn the motor by the crank 90 degrees counter clockwise then do number 2. and keep going till all is done.
bmyers4321
timmy the testie rules!!!
#7
make sure the engine is cool. i asked at work and was told the engine has to be under 100 degrees
mracer29
#8
WRONG!!! you dont do 1-2-3-4 I belive it 1-3-4-2 ill look for the link i used and get back to ya.......
Dont_Tri
#10
Does this work the same for a DOHC? I would like to adjust my valves also but this article is for the SOHC.
highcompracing
#12
yeah its the same for all Honda/ Acura and yes make sure the engine is cold. When you are done you can put put a bit of silicone in each corner before you lay the valve cover back on.
