Shiznit said:
whats the difference?
Really, the difference is that on some/most turbo cars... like mine or a wrx or evo... we use MAF sensors to let the ecu know how much air is going into the engine, and the ecu adds the right amout of fuel to match that reading... the problem with blowing off a bov into the atmosphere on a car with a MAF is that the MAF will read a certain amount of air and the ecu will pump out that much fuel for it... but once the bov opens, it releases all that air that the ecu calculated. And in return, you end up with more fuel than you do air (running rich). Recirculating the bov allows the air blown off by the bov to be shot back into the intake through a tube so that no air is lost and the air/fuel ratio going into the engine is as read by the MAF. As a result of blow off into the atmosphere on a car with a MAF, you'll run rich, backfire, some have very severe idling problems (stalling out from the engine getting flooded with fuel), and I've seens many cars actually bog at high rpms... for a while, on the freeway, if i would hold it at a certain psi that was'nt full boost, say 5psi, my car would choke really bad and jerk and feel like the engine is going to blow because of the engine being flooded by fuel. But civics use MAP sensor and not MAFs so you guys are lucky and dont have to recirculate. But anyways... recirculating = quiet, atmospheric blow off = loud... loud = cops. Hope this helps some... sorry if it's confusing.
