ej1loverr
I have a 95 civic ex non abs, the problems was the brake pedal slowly traveling to the floor while braking, if I tapped the brake pedal a little hard while starting to brake then the car would brake fine, so I decided to get rid of the problem and bought a used brake booster from the junkyard, also got a brand new brake master cylinder, installed everything, bench bled the master cylinder, then bled the whole brake system starting RR,FL,LR,RF , Now am not getting and pressure on the brake pedal, Already checked all the lines to make sure nothing is leaking, and all seems to be in order, Bled the system again and again in all orders i could think of and still not getting and pressure, ANY HELP WOULD BE GREATLY APPRECIATED THX!
