Ok guys this is tickin me off! Nothing is working, i have a cel for the vtec pressure switch but thats the only code and i removed and cleaned iacv, i tried adjusting the idle screw via the process i found on Google lolwith disconnecting the battery removing the back up fuse and unplugging the iacv all this while it is at operating temp. and also the car dies immediately when i unplug the iacv when warm as well and still nothing seems to be helping. the idle screw is tightened all the way down and no change, i tried plugging the top hole inside the tb and it stutters immediately and dies, i plug the bottom hole inside the tb and i feel light suction but no idle change. i have new plugs/wires and everything seems to be working properl. i drive it everyday and it drives normal when cold but once it warms up it starts dieing at stoplights everytime.
only ideas is obviously buy a new iacv and see if it helps, remove and clean and reset fitv, maybe get a new p28?????? IDK anymore.
and to obracer12 im gonna have to check tjat out becauase also i just now as i type this see my dizzy is missing on of the outer screws and im not sure how long its been that way so i.may be dealing with your exact issue with the dizzy.
