From a set that looked like this:
to this:
Takes several hours, a lot of sand paper, and close to 2-pounds of elbow grease.
Still have one more rim to finish and then the center caps.
Thanks Redlineobsessor (Jeff) for a good deal on the rims.
Update with some how to pics:
Step one: Remove wheel balance weight. Careful not to dig up the rim with your screwdriver.
Step two: Put on some gloves. The brake dust/snadpaper grit/ crap can and will stain your skin and take some serious scrubbing to get out.
Step three: Wet rag is your friend. Wipe down the wheel to get rid of dirt and whatnot before you start and periodically to check your progress.
Step four: Do work son! Get out your 320 grit water proof sandpaper. 3M makes some good stuff.
Step four and a half: Get the sandpaper wet and fold into a more manageable size/shape.
Step five: Got to town. Work in 8" sections of the lip. About 30 seconds on each section and move on. Keep the sandpaper wet. Once you go around a couple times, work around the entire rim to smooth out any transitions.
This is what it will look like with all the wet grit. Wipe it off to double check progress.
Almost there
Step six: Next grit. Rinse and repeat basically.
Step seven: Last grit. Rinse and repeat.
That's it for the lip. Working on the spokes is a whole other deal. Pics coming this week.
to this:
Almost there
