where the f*ck did I say it would whoop a K. I just brought up some people who run the H all day long and have beaten heavily worked K's in the same chassis. And "K-Killer" which is what DH named their CRX, I never said that anywhere. Plus I was putting their "power output" rating out there for you to see because you were wrong. And way off-topic
An H22A CRX is a straight up a FASTER car than a B18C5 CRX. With equal factors. Go ahead and favor your precious Type-R. Ask anyone with experience with BOTH engines in BOTH chassis, such as myself....or OLOCK on here he can vouch for me, or 90B16ED he can too.
I don't know why people think H-series transmissions have longer gears than they really do. They have slightly longer gears than the VTEC B's. But not that much. And in a lighter chassis, with a huge tq/wt ratio advantage, the H would move through those gears no problem (H22 LSD) Now compare it to a GSR or ITR in the same lightweight chassis, whether it be an ED, EG, or EK,the B has veeery little torque, sure it would be quick through the gears but it will fall on it's face harder than the H at that higher rate of speed..
I HAVE experience with this. My first Honda was a Prelude Si and I got rid of the H23A for a JDM H22A. I had the longest geared trans bolted on that block.....an F22A 1990 Accord CB7 transmission. STOCK clutch, and STOCK flywheel....this trans was untouched. It was OLOCK's old scrap-ass trans from his CB. I fell in love with 2nd gear. Shifting out of 2nd at 80mph was lovely. It was a bad little highway run car. Hell the hatch has to shift twice while I'm still winding out 2nd, which in turned caused some competitive, shorter geared cars to drop back or lose ground on their shifts. And I only fell 500rpm below 5k VTEC in the 1-2 gear transition. lol It was STILL faster than my JDM B16A powered 1990 hatchback I had with Clutchmasters stage 3 clutch and Fidanza 7.5 lb flywheel, not to mention I had quite a few more mods on the hatch than the Prelude. The hatch ate those gears up with next to no time between shifts. That setup was on point! It's mods Included ignition and fuel delivery components. At 90+ the hatch is TOAST. 1-3 gear the thing is rabid! But going into 4th gear on the B16A trans the car doesn't have much left. In the 1/8th mile that hatch ran a 9.6@76mph with shitty (24psi) street tires 190 wide steelies to be exact. Now add 25-30 out of an ITR and 15ft/lbs......BUT take off 900lbs off the H-powered car (My Prelude)...and then redo your equation. Make sure you have read what I just put up here. Read it as many times as it takes for you to answer this:
Which would you rather have?
A.) A gain of 30hp and 15ft/lbs (not at the wheels)
B.) A loss of 900 lbs
I think you have been getting owned enough in this thread. My statements are more than valid, while you had to bring another motor into it as an attempt to strengthen your argument. OMGXZZZZ the TYPE R IS SIK WIT IT YOOOOO!..
It's folks like you who talk ITR motors up so much, that make them overrated.
Have a good one!
P.S. There is a video of an H22A ED racing a K20R EG hatch. The ED lost by a a little over a car from 2nd to 5th gear. stock H22A trans on it too btw. It's on youtube. Look it up.
