That's new information. Redo the test described in post #57 with the replacement ECU installed. If you get the same result as before, then install new main relay fuses (there are three), inspect the fuse sockets for any signs of damage, and then thoroughly clean and tighten the critical G101 ground wire attached to the thermostat housing on the engine.Replacement ECU is same... CEL is on... No codes are throwing... I'm gonna drive it to work and back and see if anything changes... I tried pulling the fuse and disconnecting the battery after connecting the new ECU and nothing I did made any changes...
I'm beginning to think the problem has to do with the LEDs in my instrument panel... The CEL comes on bright when the car first turns on, but when the fuel pump stops priming, the CEL goes a little dimmer... When I get home I'm gonna tinker with the instrument cluster and see what happens.
