can you post a diagram of how to reset mechanical timing? i want to read through it a few times so i have the method down before i decide to do it.
Have you checked the ignition timing? I'm trying to keep you from getting ahead of yourself.can you post a diagram of how to reset mechanical timing? i want to read through it a few times so i have the method down before i decide to do it.
NOT to jump the gun here.. but are honda belts even known to jump like that.. i am NOT saying it is impossible by ANY means.. but i just have never personally known one to do that..Have you checked the ignition timing? I'm trying to keep you from getting ahead of yourself.
If a timing belt has slipped, which we don't yet know is true, you should remove the current belt and replace it with a new one. This is because you should consider a slipped belt a damaged one that is now predisposed to slip again or even break, both of which could lead to severe engine damage.
Replacing the timing belt requires removal of the crank pulley, which is the hardest part of the job. Nonetheless, with the proper tools, the job is very doable.
Yeah, it's actually pretty common for a Civic timing belt to skip one or more teeth.NOT to jump the gun here.. but are honda belts even known to jump like that.. i am NOT saying it is impossible by ANY means.. but i just have never personally known one to do that..
ok, so the ignition timing should be fine, the distributor has NEVER moved. theres enough evidence to deduce that the timing belt needs to be replaced and then set properly.
Based on your pictures, it's unclear to me that the mechanical timing is off. Checking the ignition timing will tell you whether the mechanical timing is off by a tooth. If so, you would be unable to set the ignition timing to spec. To avoid potentially removing the crank pulley for no reason, do yourself a favor by checking the ignition timing.
please ron post up the instructions and/or diagram of how to replace the timing belt.
This DIY is for a 96-00 Civic, but gives you a good sense of what the job entails.
i also found the coolant leak. The thermostat housing has that coolant pipe that leads behind the block to the water pump. The gasket between the pipe and thermo housing was pinched and was where it leaked from. i tried to reset the piping and housing, but i couldnt "pop" it in. Ron do you have any instruction for that?
Use the diagram below to identify the pipe/gasket you are talking about:
also, on the backside of the block is that black boxy thing that has an insert pipe to the block. i pulled it off to clean and i'm just wondering what that is. also the tubing on that black housing that goes to the IM kinda slides in and out of the housing....idk what it could be. maybe time to research on the honda retail site.
That's the oil breather chamber. It's part of the PCV system that reduces emissions by returning blowby gases in the crankcase to the IM.
i can't get the car to turn over.....if i cant get it to idle, how can i check the ignition timing? I can see that the crank pulley is slighty off, just to the point where it won't fully run correctly
Your engine was recently running, right? When did this happen? Does the fuel pump prime? Is there spark at all four plugs?
so the oil breather chamber is the same thing that other people buy as a performance tank that is relocated around the engine bay?
Hmmm...not sure?
