Hi hoping someone can help having trouble removing the rear shelf in order to replace the 6x9 speakers whats the best way to get that shelf out?
spoons said:mate its a hell of a job all the back seats and side pannels have to come out hell of a game.
Please do not cut the grills, that is GHETTOMugenkid18 said:if youve got a utility knife you can just cut the speaker covers off of the panel. still easier said than done tho. first you unbolt the folding part of the rear seats, it should be 2 10mm bolts on either sides of the cushions, then remove the brackets that the seats were bolted to. then remove the bench with i think a 12mm bolt in the back and pull the sides of the bench upwards and they should pop out and pull the bench out. then the side panels just pop off with some force but be careful not to brake the little snaps. after you have all that nonsense out the rear panel can finally come off. it too just pops off and voila, access to your speakers. all in all it should take like 20-30 minutes to get everything out if its your first time doing it. remember when reinstalling to do the rear panel first, then side panels, then seat brackets cuz they mount through a hole in the side panels, then the bench, then the folding seats last. hope this helps and hasnt discouraged you from your speaker install
i didnt say i recommend cutting them out lol, just an idea. when i did my speakers is the same time i painted my interior black, just another idea..K2_civic said:Please do not cut the grills, that is GHETTO
FYI, while you have it all out, might as well clean it all and wipe down the windows
NICE!EK|B said:Use this write-up, really helpful.
http://lonewolf-online.net/cars/honda/how_to_replace_rear_speakers/
Good call. Wish I thought of that before I did all my audio. Gonna be a pain when I sell the car off and want to put crap speaker back in.SweetEBPSi said:BTW, once you have everything out (seats, panels, speakers), instead of installing the new speakers the same way, bottom mount the speakers. Get some of those things that you screw into that are bent in a U shape. If you don't know what I'm talking about, go here and look in the bottom left corner of the pic. http://www.crutchfield.com/S-HMoodh6KzwS/cgi-bin/ProdView.asp?g=103200&tab=morephotos&pi=2&i=264560016&display=XL#Tab
Put those on the car and then srew the speaker to those. If this sounds confusing, I will clarify later, but not unless someone doesn't know what I'm talking about.
The reason for the bottom mount is that if you had to take them out or you got ne speakers, all you would have to do is unscrew the speaker and then screw in the new one. No need to take everything out again.
I'm sorry to say this but in your two posts about tricks you have done, you have called the tricks ghetto. Circuit City must really suck. Not saying that CC is the only place that does it, but I would definately never go there now after you telling that. There must be a lot of people that don't inspect work done when they get the car back. I'm one of those people that want it done right the first time.DaGFTDOne said:Didnt see this before, you can also cut the clips holding the screws under the deck and push the speaker up to slide it out then bottom mount..... thats kind of ghetto but thats another trick learned at CC if we couldnt just pop the rear deack easily
