if you find it let me know i have been having the same problemhm, my friend works there...maybe he can look it up.
i edited the first post stating i just replaced the alternator...
i will man...its not THAT big of a deal...its just annoying.if you find it let me know i have been having the same problem
4 gauge. and i just crimped the wires...and i just am using a regular alternator...not a high output one. and i have no amp/subs. ill try it with the radio off. im sure itll still do it though its pretty much all the lights in the carWhat gauge wire did you use for your big 3? Did you solder as well as crimp, just to be sure you're not getting voltage drops? Did you move up to a high output alternator? Are you running amps? Do you still experience the problem with the radio/amps off?
i just replaced it...alternator
no i didnt....not yetinteresting... did u have the battery checked?
and yes a battery can go bad that fast..
no...do you vaugely know what it is?your friend ever get to look up that recall info?
no, i posted about all i could remember up there ^^^no...do you vaugely know what it is?
