what size does the steel braided(kind im getting) line have to be? will -4 work?
how long have you had your turbo on your car?deftone said:for the feed line? a lot of people say thats to big... i run -3
like 2 1/2 yearsslowhatch said:how long have you had your turbo on your car?
I'd be worried the pressure to the turbo wouldn't be as great as it should be with that stealthmode fitting where it goes in the drain plug. The oil pretty much just sits in the oil pan, there is really no pressure in the oil pan. I think thats how you're saying for him to connect that.slowhatch said:if you get -4 you need to get a restrictor. http://www.wicksaircraft.com/catalog/product_detail.php/pid=4727~subid=1339/index.html thats the cheapest one i found but you have to drill it out with a 1/16 drill bit. or if you dont want to drill anything http://stealthmodeperformance.com/oil-res.shtml that will work as is.
