Overheating.
justinddelfosse
I have a 97 civic dx hatch that overheats when driving but not at idle. Found a leak in one of the lines, replaced it and looked for other leaks and didn't find any. But the engine still overheats so I replaced the thermostat thinking it might not be opening right. When I tested the thermostat it was opening until around 30°c of what it should, so I replaced it, but the engine still overheats. Any ideas? I refilled the system each time with a 50/50 mix so it's not low on coolant.
Sent from my SM-G930T using Tapatalk
:welcome:
Make sure to properly bleed the coolant system. Leaving any trapped air in the system can cause the symptoms you're describing.
