Slotted or Drilled?
Bino
what rotors do u guys use? i got a 91 hatch with the rear rotors done by me and i want to upgrade the rotors what do you guys thing i should go with? i not a track racers but i like the drilled look. i got 17 so you can really see them.
BuiltforSin
its pretty much your preference IMO. I think they disperse heat pretty much the same. personally I like the drilled rotors.
Steven.
Formally Green 91
i have 10.3 inch slotted and drilled rotors. paied about $50 for them
ryanM
its your choice, drilled disperse heat better, slotted shave off glazing on your pads. both are nice. i just went with blanks.
j_fukin_t
we have civics NOT ferrari's unless your auto-x'n then you don't need any kinda drilled or slotted
Steven.
Formally Green 91
dont NEED, but nice to have.
stealthy
4 Doors For More Whores
bremo blanks are sweet.
all go no show
Half Retarded
i use brembo blanks as well... i had a pair of drilled ones that wore very shittily, so i dont f**k with those anymore
all go no show
Half Retarded
im sure that drilled/slotted rotors have a benefit in braking, but first of all it wouldnt even be noticeable at all on the streets.. second of all, you need to buy quality parts or else they are most likely just gonna warp or crack.. so is it worth the price??? Not to me.. Just get some blanks and some nice sport pads..
Vitamin_EK9
I Do This
its up 2 u mang i had slotted on my crx and never had problems. on my coupe i had drilled and slotted and never had problems either. guess they r just for bling
Bino
thanks for the reply i really want it for the looks with my rims you like i said in my post you can see the whole rotor so i guess from the feedback its ok to go with the drilled. so where can i get some good ones cheap?
all go no show
Half Retarded
i wouldnt cheap out on rotors! Make sure to get something reputable, or just stay stock.
gearbox
go with brembo blank. slotted/drilled has no effect on braking distance and they will be weaker than stock. Only thing they might do is resist warping better, but this is only an issue on 01+ civics.
Beelzebubba
SubGenius Member
If you like the drilled look, go drilled.
I mean you might get a tiny little bit more thermal capacity at the expense of surface area. In other words, it's not going to help you any. Probably won't hurt anything other than your wallet though
Myself? I got the $20.00 blanks and painted the hats wrinkle black. They work fine.
stealthy
brembo blanks? where at?
