sparkplugs + water = ??
NoWayBack91Si
#1
Ok the past 2 days I've been doing my b16a swap today I was going to change the plugs when I looked down the holes before pulling them out there was some sort of liquid down there and when I pulled the plugs out the liquid was dripping off the plug. It didn't smell like anything so I'm thinkin maybe its water? Is this real bad? What should I do? Thanks
WalterRonny
Amante de los EG's
#2
sound like yout headgasket is fucked.. your engine start and run good?
NoWayBack91Si
#3
Oh s**t! Well I'm waiting on a subharness from hasport before I can get it to run. I'm still working on some stuff. Are you 100% sure?
WalterRonny
Amante de los EG's
#4
well, if you dont put water for over of spark plugs.. ok , for to be 100% sure, try to start it but before do it , remove cap of radiator , and now try to start it, if not starts and show like bubble, your Headgasket is fucked and you will need to check your engine too.. not scare about it , just check it ...
or MAYBE the engine you got was alot of time off recieved rain,etc.. i hope you understand what i means ;).
Good luck!
Eran
It's on ass-backwards.
#5
Can we say hydrolocked?
When my friend picked up his junkyard EJ8, it had a b16 bare block in it, and the cylinders were filled with water. At least you're not that fucked :lol:
WalterRonny
Amante de los EG's
#6
yeah.. it's possible too.
my last sentence i said .. i will tried to say the same.. sometimes it's normal that engine you get a junkyard is with water in cilinders, intake ,etc .. like said, check it .
NoWayBack91Si
#7
Ok ill check it when I finish the swap. But it was previously pulled from my friends crx and it ran fine before we pulled it
