So far ("Mod" List )
Engine
J2Racing Exhaust Manifold
Password:JDM Power Chamber
OEM Z6 Red Valve Cover
Spoon Radiator Cap
Suspension / Brakes
Interior
OEM AP1 ABS/CC Steering Wheel
OEM EK VTi Jordan Cluster
OEM EK9 Shift Boot
OEM DC5 5spd Bronze Shift Knob
OEM DC2 Rearview Mirror w/ Spoon Hydro-Blue Lens
OEM Pop-out Cuphold Console
OEM Ashtray / Lighter Console
OEM Rear Ashtray Console
Kenwood BT955HD
Kicker Comp 6.5" & 6x9 Component Speakers
Kicker Comp Amp
Kenwood Excelon Sub
Exterior
OEM Raybrig Foglights
BYS Replica Front Lip
OEM EM1 Front Grill
OEM Front Mud Guards
OEM DC5 Rear Mud Guards
OEM Wind Deflectors
OEM DC2 Rear Foglight
OEM Amber Side Markers
OEM Antenna Block Off
OEM EK9 Power Folding Mirrors w/ Spoon Hydro-Blue Lenses
Lighting has been fully converted to LED bulbs inside and on the rear.
Current Photo(s)
First Honda was a 96 Milano Red CX with a salvage title. A totaled GSR donated full power plant swap and knuckles / brakes, etc. Moved to a WRX as a daily and picked up an S13 hatchback to build on. After some crappy life events, ended up in a s***box 95 DX I bought as strictly a beater until I started to get the itch...
Then I found this spotless 2000 EJ8 EX Coupe 5spd
Clean outside, clean inside, clean title, old man driven
Typical Honda rot
Has been maintained, just not really cleaned
Then on the other hand...
Immediate goals are just going to be drive it for a while and find out what it needs. Keep it stock or at least OEM Honda. So far I know I need:
Spring bolt on exhaust manifold to catalytic converter (old spring is gone, bolt just rattles)
Tune up (hesitation in low gear, low rpms )
Possibly CV joint (or just new axles) (rotating whirr sound on left side during hard right turns)
Then little stuff like the fog lights don't work quite right and the radio is garbage (I need the tunes!)
Other goals will mostly be interior stuff to make my commutes that much more enjoyable
Suspension will likely be some of the first stuff to be swapped out as this is to and from work car so I'd like it to be comfortable and slower for now instead of fast(ish) and not so comfy. (Plus I think things like brakes, etc, should come before the powuh!)
Exterior stuff will likely just be lighting stuff for now, maybe a lip and grill to just do away with the meh.
All this time I'll need to think about a power plant. When I had my DX, I considered an F20B swap, came off of that cloud to a more realistic H22 swap. None of it ever came to be, the DX shell was in no condition for the swap. Looking more into options, power output, and other builds, I like the sound of a K series. With my Stage 2 WRX tuned and slightly modded putting out a mere 284whp (But having ridden in a 500whp Domi III STi ) I became pretty addicted to boost, so a turbo will likely come to be as well.
Check in time to time for progress on the super slow build. I photo-whore everything so there should be plenty of those for you all.
Engine
Spoon Radiator Cap
Suspension / Brakes
Interior
OEM EK9 Shift Boot
Kenwood BT955HD
Kicker Comp Amp
Kenwood Excelon Sub
Exterior
OEM EM1 Front Grill
OEM Wind Deflectors
Current Photo(s)
Typical Honda rot
