cracked manifold?
i thought you only need that if your using a boost controller, or to get the wastegate to open up. if the wastegate isnt opening shouldn't i still be seeing boostthere is no vacuum line hooked up on your wastegate!! haha. goof
either way, it needs to be hooked up. to the side. not the topi thought you only need that if your using a boost controller, or to get the wastegate to open up. if the wastegate isnt opening shouldn't i still be seeing boost
its not even hooked up.imo it might be a bad wastegate
btw what brand turbo kit is that?
how did you do this? your turbo will not correctly build pressure unless the engine is under some sort of load.what are you thinkin could be wrong w/ it. its not letting air get out i know that cuz i blocked it off and its doing the same thing
