less lol.so u have a gsr swapped eg for like 1k lol
$500 for the car
$356.50 for the swap
![Laughing :lol: :lol:](/forum/styles/default/xenforo/smilies/icon_lol.gif)
the car wotn run for a while anyway
wtf???some people cant afford a GSR.
the AEBS manifold is designed for them to run like that, but they make it so tight, it becomes a real b***h to get the clips through the hole they leave you:injector clips will be ran under the intake and through in between the runners, i will try to hide as many wires as possible
he said the thing has 80psi of compression in two cylinders....that really isnt lucky...oh so lucky....
probably. but if u put a 50 dry shot on your car, i wouldn't call you lucky...i bet its faster than my car the way it is
car dollyu gonna push it up there?
u can run obd-1 and re-wire it....thats what i did. or u can run obd-2....whatever u want. what do the injector clips look like?so, i just realized, the harness on the motor must be OBD2, because there is only 1 dissy plug, so that means i need a OBD2 GSR dissy? or can i get a OBD1 and rewire it?
working on pulling the head now...
they are OBD2 clipsu can run obd-1 and re-wire it....thats what i did. or u can run obd-2....whatever u want. what do the injector clips look like?
thats so awesome!!!!!!!!!they are OBD2 clips
u can run obd-1 or obd-2 distributors on either ECU....same with injectors.is the ecu obd1 or 2. what ever it is that is what you need to run.
