Featured Ride Contest #2
Who do you think should win our Featured Ride contest?
  • Total voters
    50
  • Poll closed .
Status
Not open for further replies.
vjf915
Featured Ride Contest!!
Please review EACH contestant, and then vote for who you think should be the winner!! The poll options are listed in the order that the contestants are listed below, and their usernames are in blue above their ride details.
Cpt Karacho
Vehicle: 1997 Honda Civic
Engine:
-D15Z6 (75,5mm)
-D16Y8 head (fully optimized)
-JE-Pistons D15B2
-Crower Rods D15B2
-Blox Valves
-Blox Titanium Retainer
-Supertech Valve Springs
-CompCam Stage2 Camshaft
-Skunk2 Camgear
-Cometic Head Gasket
-NGK Spark Plugs (from a Honda Boat Engine → Shorter Electrodes --> 7/10mm from plug to piston)
-Vision 10,2mm Ignition Wire
-D15B2 Camshaft-Pulley (finely balanced)
-F1-Racing Flywheel with 4kg (finely balanced)
-Blox Intake Manifold (fully optimized, adapted to the head)
-D15Z6 throttlebody (widened to 57,5mm, tapered, spacer from 57,5mm to 64mm -->IM)
-Universal Intake 3“
-DC2 K&N Airfilter (Cold Air Intake in the Bumper)
-DC2 Injectors
-AEM FuelRail with AEM Fuel Pressure Regulator
-D13 S20 Gearbox with Mfactory Helical LSD
-specially produced sintered metal clutch by GRacing (Greece)
-Blood Sports 4-2-1 Header, adapted to the Head
-200 cell catalysm adapted to header and catback
-Hondatwincam Catback with 2,36“ outer Diameter
-Oilcatchtank
-Energy Suspension and Prothane PU Engine Mounts
-NRG Engine Damper
-Mishimoto Water Cooler
-P28Ecu and OBD1
-Racimex Oilcooler
Suspension/brakes:
-Koni adjustable Yellow Shocks
-Eibach Springs
-EK4 rear axle with Stabiliser
-Energy Suspension Master Kit
-DC2 front Calipers
-EP3 rear Calipers
-EBC Discs
-EBC Greenstuff Pads
-Goodridge Lines
-DC2 brake booster and master brake cylinder
-OEM EP Preface Wheels, 16x6 ½ w/ 45 offset
-Falken Ziex912 195/45 R16
Exterior:
-OEM Sport Front and Rear lip
-FogLights
-JDM EK9 Rear Wing with Brackets
-Carbon Hood with Tilt
-OEM Window Visors
-JDM Block Off Plate
-TSS RearLights with „BrakeLight“ Mod
-Headlights anthrazit painted
-Homemade OEM Rearbumper
Interior:
-Mugen Pedal Set
-Mugen Shiftknob / Spoon Shiftknob in exchange
-Fastline Performance Shifter
-Momo Tuner Steering Wheel with Quick Release and complete restored steering wheel from a bmw 2002 from 1970 also with Quick Release in exchange
-OEM Airbag Tray
-Recaros Speed Seats
-Vision Low Position Seat Rails
-OEM Armrest
-JDM Cupholder
-JDM Roofconsole
-Takata Harness
-2x OEM Extinguisher
-Alpine Headunit
-Axton Front and Rear Speakers with Amplifier
-OEM Black Leather Facilities and Body Color Seams and Honda Stitching on Headrests
-Black Leather Shiftboot and Handbrakeboot with Body Color Seams
-STRi Gauges for Oiltemp., Oilpress., Exhausttemp., Fuelpress. and Manifold Vakuum
-Summit B+C Pillar Bar
-S2000 Start Button
-S2000 cluster
Mugenej8
Vehicle: 1996 Honda Civic EX
Engine:
B16A2 Motor
Del Sol P30 Obd2a Ecu
Ctr Camshafts
ITR Valve/Springs
ITR Transmisson 4.7 FD
ACT Stage 2 Clutch
Exedy 12lb Fly Wheel
ACT Pressure Plate
Rsx Type S OEM Exhaust
Dc Ceramic Header 4-1
Password JDM Intake
Skunk2 Short Shifter
Energy Shift Bushing
Samco Blue Hose
BDL Blue Fuel Rail
JDM Ctr Red Valve Cover
Password JDM Carbon Spark Plug Cover
Mugen Oil Cap
NRG Blue Engine Torque Damper
NRG Polished Hood Damper
Polished Radiator Bracket
Silver Vtec Solenoid Cover
Suspension/brakes:
Nitto Tires
Rota Circuit 8 Bronze/ Upgrading SOON!!!
Gsr Rear Disc Brake Conversion
Tokico Illuminas Adjustable
Skunk2 Coilovers
3 Point Front Strut Bar
Trunk Strut Bar
Blox Blue Lower Control Arms
Beaks Gold Tie Bar
Revo Front Ball Joint Camber Kit
Revo Rear Camber Kit
Exterior:
Pure White Paint
Mugen Lip
Black housing Headlight
Civic Type r Grill
Stanley Side markers
Ctr Thin Moldings
Ctr Style Rear Lip
EDM Rear Fog
License Relocator
Oem Civic Si Spoiler
Oem civic 99-00 Tail lights
Red Honda Badge
Xenon HID 8k
Square Fog Lights
Interior:
Civic Si Cluster
Ctr Carbon Faux Bezel
Ctr Steering Wheel
Ctr Red Carpet
Ctr Armrest Delete
Ctr Red Recaro SRD
Ctr Door Panel
Skunk2 Shift Knob
Ctr Shift Boot
Broadway mirrior
S2k Push Start Button
Front Speakers Polks DB650
Rear Infinity Kappa 692.9i
Pioneer Deck w/usb & aux
Eran
Vehicle: 1997 Honda Del Sol
Engine:
B16A2 block with polished P30 Head
Rebuilt Y21 Transmission with MFactory 4.9 F/D
P73 ITR Intake Manifold
CTR N1 Enduro Crank Pulley
P28 with Demon 1.2 tuned on Neptune RTP
Vision Motorworks 65mm Throttle Body
Weapon R 4-1 Header (Mugen 4-1 Copy)
ThermoCool Exhaust Manifold Wrap
EG2 SiR Airbox w/ DC Sports Foam Filter
NGK Plug Wires
Mishimoto Dual-Core Radiator
Honda OEM del Sol VTEC Exhaust B-Pipe
Spoon Sports Street Muffler
Suspension/brakes:
B+G S3 Coilovers (ITR Spec)
ITR Rear LCA
CTR 22mm Rear Sway
del Sol 22mm Front Sway
ASR Subframe Brace (Grape Drank!)
Ultra Racing Front Tower Bar
Carving Stark RC 15x6.5 +32
Yokohama S.Drive 205-50-15
Exterior:
Civic EX/Si Front Lip
JDM Rear Plate Fillers
EG2 del Sol Yellow Fog Lamps
CR-X VXi emblem conversion
del Sol 'Two-Way Paradise' sail decals
EDM glass 2-piece electronic leveling Headlamps
OEM Antenna Blockoff
OEM Half Nose Mask
Downstar Inc. Engine Bolt Kit
Integra Type-Rx Plug Cover
Vision Technica S2000 Oil Cap
Interior:
Personal 'Work EQUIP' Steering Wheel with Horn Pad
Works Bell Splash 210 Hub
Spoon Sports Titantium Shift Knob
Honda Access 'Powered By Honda' shift boot
Chargespeed Sport FRP Wide Bucket
Wedge Engineering Brackets w/ Sparco Sliders + Sidemounts
JDM Map Lights with Polarg B1 Hybrid VIP bulbs (purple)
EDM/GDM Sun Visors w/ Mirrors
93 Dash (SRS delete)
93 Glovebox
93-94 del Sol Zig-Zag mats (grey)
93-94 Trunk Latch Delete
94-95 VTEC tachometer
95+ Honda Genuine USDM seat covers
NA Miata green lighting
Custom Headliner
Odyssey PC680
Sony XPLOD CDX-GT730UI
Infinity BassLink Powered Woofer
Memphis Power Reference Rear Drivers
Diamond Audio Front Components
Monster Cable RCA
Vehicle: 1996 Honda Civic LX sedan
Engine:
JDM B18B +T, 62k on head, 50k on block
250whp / 210tq @10psi, stock block internals
Automatic to 5 Spd Manual conversion
Garrett T3/T4 Turbooo, .60 trim, .48a/r
TiAL 38mm wastegate
HKS SQVIII BOV
ARP head studs
Crower double springs, titanium retainers / keepers
Avid Billet "Sleeper" mounts, 75A Race bushings
Competition Stage 2 clutch
3" downpipe / exhaust, cat-less
Injector Dynamics 725cc Injectors
Mishimoto performance radiator
Password JDM radiator stay
Walbro 255lph fuel pump
P06 ECU Chipped w/ Neptune
Tuned by Morgan & Greg @ Synapse Motorsports
Suspension/brakes:
DropZone struts / coilovers
16" Enkei wheels, Toyo Proxies
Exterior:
15% tint all around
Mugen replica front / rear lips
Type-R replica grille
Interior:
GlowShift Digital Wideband A/F gauge
GlowShift boost gauge
eBay shortthrow shifter/knob - Energy Suspension bushings
Authentic Type-R shift boot
Alpine CD deck w/ iPod hookup
JL Audio 12" W3
Kenwood mono amp
Spyro
Vehicle: 1999 Honda Civic EX
Engine:
Bone stock D16y8 SOHC 1.6L Vtec
Cruise control
Power steering
Automatic transmission
Stock exhaust system
52k original miles
Suspension/brakes:
Stock original Honda Civic EX suspension
Stock control arms (front and rear)
Exterior:
15 inch Black Rota GT3's
CTR grille
CTR style poly lip
JDM yellow fog lights
JDM black housing headlights
8000k Blue HID kit
Ferio 50/50 tail lights
Rear red Honda emblem
PasswordJDM rear visor
30% tints (rear, sides, and moonroof)
Custom JDM "Young Driver" badge sticker
Interior:
Super clean mint condition stock front & rear seats
Original Honda carpets
OEM power sunroof/moonroof
OEM power Windows
7" Panasonic touch screen flip-up (removed to purchase a new 7" in-dash double-D with navigation)
Tweeters
Sound system equailzer (vocal, bass, tweeters)
12" Kicker SoloBaric L5 subwoofer
Viper alarm system with remote starter
civic209
Vehicle: 2004 Honda Civic EX
Suspension/brakes:
-Rokkor Coilovers
-Ingalls Front Camber bolts
-Ingalls Rear Camber Arms
Exterior:
-HFP Aero Lip Kit
-Depo Foglights
-DDM Tuning HIID's in 6k, 8k, and 3k in lows, highs, and fogs
-OEM Spoiler
-OEM Half-nose bra
-17x7 XXR 521's
Puma
Has no filter
I can't decide between a couple of cars!
wazup_74
wow, this is going to be hard. I think i've narrowed my choices to Eran, Mugen, and CPT.
Very tough choice though....
civic209
^^:cry:
Lol i think its time a 7thgen wins one of these dont you guys think? :lol:
edit: aww come on guys if i wouldve named all the stock stuff my car has my list of modifications would've been a lot longer as well..
vjf915
I'm going to have to hold out on voting, as I really can't decide either. There's two cars that are a tie in my head, and I'm going to have to mull it over before deciding.
civic209, it would be great if a 7th gen wins....one that's deserving of winning. I don't know of too many 7th gens that are more deserving than two or three of the cars in just this contest....the only one I can think of is sniperscouts, and he hasn't been on in a while.
Puma
Has no filter
^^:cry:
7th gens are like the black sheep of civics IMO. I haven't ever seen one done properly to me. 6th and 8/9th gens are my favorite.
Mines a toss up between the hatch and the coupe. Can the owners of those cars possibly post up a link to more of their cars w/o whoring out the thread too much??
civic209
You guys can all go to hell! :cry::cry:
:lol: well one of these days i will fix up this auto and make the engine bay look real nice...you will see :D
Puma
Has no filter
Cosmetically I don't like them.
civic209
Whats not to like? The interior is far superior to that of the 6th gen and the exterior gives a substantial amount of room for a stylish look. Id pick a 7thgen over a 6th gen any day.
Puma
Has no filter
Let's not whore this thread out and keep it to the contest. Either PM me or FB.
FlipSkater079
7th gen love!
You should get some better pictures!
Also I'm not a fan of the wheels.... But like everything else!
wazup_74
^^:cry:
To be honest I'm only looking at the parts list to reference back not primary decision.
I love 7th Gen and think Honda did a great job with them styling wise. But that's the thing, not much mods available like other gens. I like yours but here's my thing.
auto -1
engine bay looks good and well kept. +1, but -1 at the same time, nothing "impressive" there. So maybe +.75
interior again nothing "impressive" or that pops out. One thing I feel changes the interior a lot is steering wheel. subtle differences do it for me a lot of times.
Sniperscouts car is by far THE best 7th Gen I have EVER seen. Wish he came around a bit more.
wazup_74
Better pics would've helped. Maybe "hard wiring" the GPS, or making a "cleaner" install would help. Little things like that.
vjf915
Cosmetically I don't like your face.
Okay in all seriousness, I've made this argument many times.....anyone who can seriously like the 6th gen styling, yet dislike the 7th gen styling clearly has no sense of taste. It's not even an opinion either. The 6th gen has the advantage of MANY aftermarket parts....but that's it. The interior styling is MUCH better than the 6th gen, it doesn't look like an "econo-box" interior, it actually looks pretty damn nice. And the black interiors are true black, as opposed to the 6th gens gray....black is nicer. As for the exterior, there are two major differences between the two. The 7th gen has different tail lights, and it doesn't have the side moldings on the doors. No side molding looks better, and the tail lights are personal preference. Different tail lights are not going to make or break the car for me, especially with a much better interior.
Take a look at the actual BODY LINES of the 6th and 7th gens. They are actually the closest styled Civic's from different generations. I simply don't understand how anybody can dislike them when they are so similar in styling. Yes, the aftermarket support gives a great advantage to the 6th gen....but we're talking about the body lines. The front bumper, headlights, hood, the doors, rear windows, rear bumper.....are all nearly identical.
FlipSkater079
To support this argument/end future arguments here are 2 fairly similar pictures.... The 6th gen is even a 96-98 and they still look alike.
Cpt Karacho
the link in this forum:
http://www.clubcivic.com/board/showthread.php?t=192182
the complete story:
http://www.civicboard.de/mini-me-sohc-n-a-d15-frankenstein-t10723.html its much to read
and here the project:
www.projekt-ej9.de
in know, the pics aren't the best, so i hope you like the car and not the bad pics of them....:???:
civic209
The only difference is that the 7th gen is sexier, as explained in previous posts.
lethal6
Your Mom's Moderator
It comes down to the automatic trans. With civics it's a big turn off for me, especially in a featured car. That is why the last 2 get scrolled right past.
I also don't even look at the mod list until after I look at the pics, unless it is turbo'd. If it is then I scroll up to see if it is a legit kit or a junk bys. Let's face it, there is no mod list on the main page of the site. THAT is what draws you into the featured section, NOT a list of parts. The add ons are just desert.
As far as the 6th and 7th gen debate. I chose 6th and the main thing that does it for me is the head lights. The 7th gen ones look rushed, squished, and weird.
vjf915
Squished? Again, the headlights are nearly identical. The only major difference is the top outside corners of the 7th gen are more pointed.
Status
