Finally another update. I took out the carpet from an Si Crx and replaced my blue carpet with it.....
And theres my new carpet. Now all I need is the dash.
And more Important.....
Finally got my block....
spec sheet is pretty much this
-usdm b20b4 block
-custom benson knife edged crank, micropolished + blueprinted
-eagle rods
-arias 12.5:1 high comp hand polished pistons, 84.5mm
-arias piston ring set, 84.5mm
-block deck has been check for warpage and it turned out perfect
-itr water pump
-arp rod bolts
-oem bearings
-oem oil cooler
-itr oil pump (not installed yet)
